Hey guys, I have been reading this site daily for quite some time now and finally decided to make an account. I have gotten some great information from this board.
Anyway, I have a 2003 Ford Escape with the 3.0 duratec v6. It has 85,000 miles on it and is in decent shape. It was previously a one owner car, but it seems that only basic maintenance was performed. I figured that because everything is already ten years old it could use a tune up. I have not been getting the greatest gas mileage but there are no codes (not even pending). I have two questions:
1. Would you recommend the tune up? I planned on doing it by 100k anyway.
2.Does anyone recommend any specific parts or methods for completing the tune up? If I did do the tune up I was planning on doing it myself as I do have mechanical experience just not with these engines.
Parts I had planned:
Denso or Motorcraft platinum plugs
Denso Ignition coils
Fel pro Upper and Lower Intake Manifold Gaskets
Fel pro valve cover gasket set (I found oil in a plug well when I changed a front plug/coil)
Motorcraft PCV
Motorcraft PCV
