Hello all -
Pipe To Rear Heater Rusted-out And Leaking. How To Plug Pipe? (OK To Disable Rear Heater!)
Per the title, this is Jr's 2002 Mazda MPV. The van developed a severe coolant leak this morning while our daughter-in-law was driving. (Murphy's Law - Our son was on a bus to help out at a summer camp which our grandson is attending.)
Anyway, we got the van towed over here, and I found that one of the steel pipes to the rear heater is rusted through. There was a plastic shield above the RR wheel which was probably intended to provide protection, but instead trapped mud.
I think the best way forward is to cut the line off before the rust and cap it.
Please suggest products I could use to cap the two lines (pipes) off. Both pipes are steel, and about 17 mm O.D. I don't know the I.D.
Another possibility is to clamp the short rubber hoses under the van, where the hoses provide a transition between the steel pipes.
I even wonder if I could loop a hose from the supply pipe back to the return pipe instead.
Ideally I could disconnect the pipes to the back up front, but access to the firewall is not good.
Any suggestions very appreciated!
