2002 Chevrolet Monte Carlo SS 3.8L.
Down & Out
I'm going to start with a little vehicle history. The vehicle is a 2002 Chevrolet Monte Carlo SS. 174k miles. I am the second owner, my aunt was the first. I got the car with 118k. When I purchased it, the engine had a slight rod knock. I knew the engine was going to fail just a matter of time. Unfortunately at 174k the engine did fail.
Suffered from catastrophic bearing failure. For those 56k miles I drove it I used Mobil 1 Extended Performance 10w30/K&N Filter or Amsoil Signature Series 10W30/Amsoil Filter. 5K OCI.
With the new engine I am starting out fresh and on the fence on what kind and type of oil I should be using.
After break in process should I go back to my 5K OCI habit with the same oil or use conventional and a 3K OCI?
I'm open for suggestions.
Considering it has 174k, the 2nd engine will outlast the rest of the car. I would just use a cheap (yet good) oil for a moderate oci and not worry. My suggestion - any 5qt jug under $20 such as Valvoline conventional or Maxlife.
I'd go for Mobil Super 5000 5w30 or Valvoline 5w30 conventional for 4-5K OCIs.
Those 3.8s aren't known to die like that. Odd.
My aunt had it before me. If it was starved for oil or ran hot a few two many times. I'm not sure. From what happened, seems to be a good possibility.
I think 5000 mile OCI with the oil of your choice should suffice. U can go 7500 or more mile OCI with good synthetic oils.
Originally Posted By: Tdbo
I'd just use whatever name brand dino is on sale and call it a day.
+1 - if nothing is on sale, SuperTech conventional 10w30 is fine.
I'd run the (dexos approved) Pennzoil Synthetic Blend 5w30 with a quality filter, and change it every 5,000 miles. Problem solved.
This stuff is 50% synthetic, and is only a couple bucks more than Pennzoil conventional. I'm running it in two GM 5.3 V8's, a Chrysler 3.8 V6, and a Ford 6.8 V10.
If it is good enough for a new Corvette... then it is good enough here.
I had a 2001 impala with tis engine, 177,000 miles on it when I traded.
These engines were spec'ed for 10w30 oil. Any modern oil is good enough, but I use synthetic in all my engines.
I have used 5w30 & 10w30 conventional and synthetic in my Series 2 supercharged 3800 throughout the years. It will do fine on any recommended above. My vehicle liked the Quaker State Ultimate Durability the best as rated by the purrt, butt dyno and unofficial mpg test.
Originally Posted By: gregk24
Any API SN 5w30 at 5k intervals for the life of the car.
I thought the Series II called for 10w30? I know the 3800 Series II in my Firebird is speced to use 10w30 in temperatures above freezing, and 5w30 for the winter. Granted, I highly doubt it matters much in the grand scheme of things but I thought I'd mention it anyways.
I hope it holds on for a while. I installed a Triple Edge Performance Shift Improvement kit, change the filter, fluid and has a tune.
