Hi,
Car currently runs on Magnatec 10W-40 A3/B3 - Part Synthetic Technology
ACEA A3/B3
API SL/CF
MB 229.1
VW 505 00
Test Method(s) Unit Typical
Density @ 15C ASTM D4052 Relative 0.873
Viscosity, 100C ASTM D445 mm²/s 14.34
Viscosity, 40C ASTM D445 mm²/s 95.3
Viscosity, CCS -25C
(10W)
ASTM D5293 cP 6140
Ash, Sulphated ASTM D874 % wt 1.0
Total Base Number, TBN ASTM D2896 mg KOH/g 8.0
Pour Point ASTM D97 °C -36
Above was put in by my garage, which I'm not sure it's the best for me.
Regarding the CAT /Mobil Delvac, I had found this from the Mobil
https://www.mobiloil.com/USA-Englis..._vs_Mobil_Delvac_1_for_a_Gasoline_Engine.aspx website: which explains the advantages of the DELVAC over M1"
Mobil Delvac 1 ESP, which is designed for heavy-duty diesels, meets most diesel engine oil specifications, and also meets API SM certification. And because Mobil Delvac 1 ESP operates in a different environment – diesel engines run longer, generate soot and run hotter, it contains different types and amounts of additives than Mobil 1. Even so, Mobil Delvac 1 ESP still meets API SM certification for gasoline engines, and because of its high performance, we would expect it to do a good job of protecting your gasoline engine.
If you use your gasoline vehicle in "heavy-duty" service, Mobil Delvac 1 ESP will provide many benefits compared to conventional oils. When compared to Mobil 1 performance, those benefits may not be as obvious, and in fact, Mobil 1 would be expected to outperform Mobil Delvac 1 in many gasoline applications. (Updated April 2008)
While: Delvac values -
SAE Grade 5W-40
Viscosity, ASTM D 445
cSt @ 40ºC 98
cSt @ 100ºC 14.7
Viscosity Index, ASTM D 2270 156
Sulfated Ash, wt%, ASTM D 874 1.0
Total Base #, mg KOH/g, ASTM D 2896 10.1
Pour Point, ºC, ASTM D 97 -48
Flash Point, ºC, ASTM D 92 249
Density @ 15ºC kg/l, ASTM D 4052 0.85
CAT DEO SYN values -
SAE Viscosity Grade 5W-40
API Service Classifi cation CI-4PLUS**, CI-4, CH-4, CG-4, CF, SL
OEM Performance Levels:
Cummins 71/76/77/78
Mack EO-NPP ’03, EO-M Plus
MB 228.3
Volvo VDS-3
Caterpillar ECF-1-a
ACEA E5/E4
Gravity, API 34.1
Specific 0.85
Pour Point, °C (° F) -45 (-49)
Flash Point, °C (°F) (ASTM D92) 226 (437)
Viscosity:
cSt @ 40°C 95.0
cSt @ 100°C 14.8
SUS @ 100°F 440.0
SUS @ 210°F 77.9
Viscosity Index 151
Zinc, % wt. (ASTM D4951) 0.146
Sulfated Ash, % wt. 1.35
TBN (ASTM D2896) 12.0
Looking into the UK Castrol site (UK- UK make Land Rover), they recomend:
Castrol Magnatec Professional A1 5w30
API SM/CF
ILSAC GF-4
ACEA A1/B1
Meets Ford WSS-M2C-913-C, Ford WSS-M2C-913B, Ford WSS-M2C-913A
Appearance Visual Clear and bright
Viscosity, Kinematic 100C ASTM D445 mm²/s 9.7
Viscosity, Kinematic 40C ASTM D445 mm²/s 55.39
Viscosity Index ASTM D2270 None 161
Calcium, % wt ASTM D4951 % wt 0.242
Phosphorus, % wt ASTM D4951 % wt 0.091
Zinc, % wt ASTM D4951 % wt 0.099
Flash Point, PMCC ASTM D93 °C 210
Pour Point ASTM D97 °C -39
High Temperature High Shear CEC-L-36-A97 °C 2.95
I find it's grade too low for my climate 45C at summer (desert).
They recommend as well the:
Castrol EDGE 5w30
VW 504 00/ 507 00
MB-Approval 229.51
BMW Longlife-04*
* (do not use in BMW gasoline engines outside EU)
ACEA A3/B3, A3/B4, C3
Density @ 15C, Relative ASTM D4052 g/ml 0.8513
Viscosity, Kinematic 100C ASTM D445 mm²/s 12.0
Viscosity, CCS -30C (5W) ASTM D5293 cP 5800
Calcium, % wt ASTM D4951 % wt 0.148
Phosphorus, % wt ASTM D4951 % wt 0.078
Zinc, % wt ASTM D4951 % wt 0.086
Viscosity, Kinematic 40C ASTM D445 mm²/s 70
Viscosity Index ASTM D2270 None 169
Flash Point, PMCC ASTM D93 °C 202
Ash, Sulphated ASTM D874 % wt 0.64
Total Base Number, TBN ASTM D2896 mg KOH/g 7.0
While on their site there is the:
Edge Turbo Diesel 5W-40
VW 502 00, 505 00, 505 01
MB-Approval 229.51
BMW Longlife-04
Meets Ford WSS-M2C917-A
RENAULT RN0710 / RN0700
Meets Fiat 9.55535-S2
API SM/CF
Relative Density at 15ºC ISO 3675 / ASTM D1298 g/cm3 0.85
Viscosity at 40ºC ISO 3104 / ASTM D445 mm2/s 82
Viscosity at 100ºC ISO 3104 / ASTM D445 mm2/s 13.9
Viscosity Index ISO 2909 / ASTM D2270 - 174
CCS -30ºC ASTM D5293 mPa.s 5550
Total Base Number ASTM D2896 mgKOH/g 7.6
Flash Point (PMCC) ASTM D93 0C 210
Pour Point ISO 3016 / ASTM D97 0C -48
Sulphated Ash ISO 3687 / ASTM D874 %m 0.80
and for the Mobil 1 0W-40
Value
Viscosity, cSt (ASTM D445)
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
MRV at -40ºC, cP (ASTM D4684) 31,000
HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, ºC (ASTM D92) 230
Density @15.6 ºC, g/ml (ASTM D4052) 0.85
Which I don't know if I can get it down here...
Since the CAT DEO SYN is made by MOBIL, a well known manufacture, I would go with it, but it has relative high Ash, Sulphated as 1.35.
Since I had replaced my OIL pump and Turbo for NEW, I would like to use the BEST suitable oil for this engine.
Would not want to mess new parts.
Sorry for the TMI here on this message, but I wish to make "life easy" for guys to review the specs, not running to the internet searching for data.
