Originally Posted By: jeepman3071
Originally Posted By: Miller88
Donald, you and I have the WORST year 4.0. Chrysler really managed to mess up an otherwise very reliable engine for these years.
Head cracking seems to be pretty rare on WJs and TJs - their cooling systems have quite a bit more capacity and don't overheat as bad when they wear out. 0331 head problems seem to be extremely common on XJs because the small cooling system.
Piston skirts ... that's not something that can be avoided. I do see a lot of WJs on CL for < $1000 with knocking engines.
I will be pulling my T6 out around June this year. I should get a UOA. I'm afraid to see what my aluminum will be
I'm fairly certain that I do not have a cracked head. I have a small weep from the WP gasket and I have only had to add 4 or so oz of coolant in 2 years.
I can't see the results of the UOA, so I can't see what the numbers are.
If you only have to add 4 oz of coolant in 2 years I doubt your head is cracked. The 0331 heads do crack, but the internet greatly over emphasizes the issue, and I feel the 0331 head is a more common problem than the piston skirts. Many Jeep 4.0s are on the road without issues.
With a sensor for low coolant, it would seem to be hard to be unaware of loosing coolant.
Not sure about the cracked #331 head issue but local shop said then had done a few 4.0 engine replacements due to cracked piston skirts, with mine being one of them.
