2001 infiniti i30
amsoil atf 14,868 miles
186k on transmission
First analysis on this transmission had magnefine filter installed
what do you guys think? wasnt too sure what blackstone meant about oil filtration overloaded thanks
The viscosity of this ATF was normal (20W) and no moisture was found. Wear metals generally
read low, with copper reading a bit above average, but not by that much. This metal is from clutch plates.
The 0.4% insolubles were mostly metallic, though some appeared to be oxidized oil. This concentration of
insolubles shows that oil filtration was overloaded and in need of service. If this transmission runs well,
check back in 20,000 miles to monitor. Universal averages show typical wear levels for this type of transmission
after about 22,500 miles on the oil.
universal averages
aluminum 4 13
chromium 0 0
iron 29 72
copper 59 37
lead 5 5
tin 4 2
MOLYBDENUM 1 1
nickel 0 0
manganese 1 1
silver 1 0
titanium 0 0
potassium 2 3
boron 170 56
silicon 8 18
sodium 8 9
calcium 93 112
magnesium 1 7
phosphorus 545 362
zinc 9 29
barium 0 6
values should be
SUS Viscosity @ 210°F 47.0 43-51
cSt Viscosity @ 100°C 6.35 5.1-7.9
Flashpoint in °F 440 >355
water% 0.0 Insolubles % 0.4
universal averages
aluminum 4 13
chromium 0 0
iron 29 72
copper 59 37
lead 5 5
tin 4 2
MOLYBDENUM 1 1
nickel 0 0
manganese 1 1
silver 1 0
titanium 0 0
potassium 2 3
boron 170 56
silicon 8 18
sodium 8 9
calcium 93 112
magnesium 1 7
phosphorus 545 362
zinc 9 29
barium 0 6
values should be
