- Joined
- Feb 6, 2025
- Messages
- 807
Try it without the thermostat. That's supposed to make engines run too cold.
Isn't this the one you swapped motors on? I recall something missing a cylinder.
Have you run it w/o the cap? I wonder if it popped a head gasket already.
Bummer.![]()
I think I’m going to try a 180 and see what happens. If that can get me to work before hitting failsafe mode then that’s the fixTry it without the thermostat. That's supposed to make engines run too cold.
No. Go straight to the no T-stat. Remember it's just a test.I think I’m going to try a 180 and see what happens. If that can get me to work before hitting failsafe mode then that’s the fix
I noticed you hadn't indicated boiling, so it didn't seem right... but I'm at a loss here (no surprise, not a mechanic). There's something stopping flow.I don’t believe it’s lost a head gasket or cracked a head. It doesn’t bubble or boil coolant. Or lose any coolant. Any time I’ve seen a head gasket let go it’s made the coolant boil or bubble. I don’t see that
If it’s of reasonable quality it won’t. This gets done on old MB diesels often as part of the FSM recommmendations.The citrix acid flush scares me. I don't want to eat a 25 year old heater core. That would be the end of the vehicle. I guess I could just bypass it temporarily.
But just watch the ratios.
Maybe I missed something. Have you fully flushed and flowed pressurized water through? Like remove the hoses, remove the radiator, and flow it?
Have you looked at the impeller of the water pump?
Have you verified the sensor is correct?
I wouldn’t count on an IR thermometer for this.
I once had a 1993 Jeep Cherokee. I chased an overheating problem forever and put in a new water pump, heavy duty radiator, new hoses, new t-stat, etc. The gauge still indicated that it was running hot. Turned out to be a bad temp sensor. $15 and it was back to running cool. The old temp sensor was indicating a higher temp on the gauge than it actually was operating at.
At highway speeds if you are still running hot you either have poor coolant flow, or poor airflow through your radiator.
Warm it up. Shut it down and immediately feel the radiator core. Feel for cold spots.I'm thinking it's the radiator, it's somehow plugged up, not actually flowing. I wonder if you could get one of those borescopes and see what can be seen in the tanks? but it could be plugged elsewhere.
While it's running at 230 I can't touch the driver's side of the radiator, but I can touch the passenger (outlet) side of the radiator and it's lukewarm. It does gradually get cooler the closer I get to the outlet.Warm it up. Shut it down and immediately feel the radiator core. Feel for cold spots.
Is it the original water pump?Water pump has to be pumping because the heat works.
It's a new water pump. The old water pump had perfect impeller fins. It unfortunately got destroyed upon removal so I'm only able to use the new pump.Is it the original water pump?
Have you considered the possibility of a worn impeller?
Try the Prestone coolant system flush. I agree it sounds like you don't have enough coolant system pressure.I'm at a loss here. This is my 2001 Grand Marquis , 175K miles on the car ... 160K miles on engine.
I noticed this spring/summer that the fan was running pretty much constantly. According to the torque app, it was running around 225 on the highway. If sitting still, it would cool down.
When I got the car 5 years ago, I'm pretty confident I was the first person to ever change the coolant. Numerous coolant flushes and it still turns brown quickly. But it never had any overheating issues. It always seemed to run right around 200 -210 and I never heard the fan come on unless I turned on AC
This year it's been worse. We had a day last week where it was 100F out and it couldn't keep up. Even with the heat on full blast, best it could do was 235. It kept going into failsafe cooling mode if I didn't have the heat on full blast. That means it was hitting 260... Even when it hit 260, the coolant wasn't boiling but I could tell it was HOT. There's 2 temp sensors - one of the gauge and one for the computer. If they're both agreeing that something hot, I'd be inclined to believe that it's not a bad sensor.
I put a new 195 degree thermostat in. Didn't help. Changed the water pump and radiator and same problem.
It's not boiling the coolant or using any coolant. No milkshake in oil or on the oil cap ... not that oil cap is a good indication on a 2 valve Ford anyway - they always milkshake the oil cap). The weird thing is, yesterday when it was running at 230, I was able to squeeze the upper radiator hose and opened up the cap and it didn't even have any pressure on it?!
There is definitely coolant flow. Heater is blowing hot. Old water pump was perfectly fine. When I pulled the radiator, I back flushed it a bit and got a bunch of crap out of it.
If I put my hand over the new radiator, I can tell it's definitely doing something. Warm on the driver's side, cool on the passenger side.
