2001 GMC Starting Problem??
How can a shop make decent money charging only $100 to drop the gas tank and replace the pump? That era of truck , I think, needs the fuel pump pigtail replaced also at the time of pump replacement.
It certainly helps that you are not in the rust belt. Still, a hundred dollars?
What make of fuel pump was installed?
The $100 was the labor. The pump was like $270. They Took the bed bolts out and used the lift and picked up the bed. Changed the pump and put it back together.
