2001 dodge neon coolant reservoir
Golden Meadow, LA
I need to change the coolant reservoir on my neighbors '01 neon, its bolted to the firewall on the drivers side. Theres a black box with some vaccuum lines almost directly above the reservoir, that I would need to remove in order to get the reservoir out. It looks like its riveted in place, can anyone confirm this and tell me the proper way to remove it the box?
sounds like the vacuum reservoir for the cruise control system...
unfortunately my neon wasn't equipped with cruise, so i never had to deal with the systems...
pm me your email, and i can send you the FSM for those cars in PDF form.
short version - they aren't rivets. held in with 2 nuts under the passenger side cowl screen.( the cowl is in 2 pieces.)
as for the coolant. G-05 is the most readily available version of the recommended mopar coolant.
