Hi guys.
I need a help here.
2001 model SXV20R 5sfe Camry auto.
engine cold start idle speed sitting around 900RPM then surging.
cleaned the IAC valve by spraying carby cleaner in the hole in the bottom of the throttle body,Removed the electrical solenoid and span the IAC valve shaft seems to be nice and free.Defenitly not sticking.
Replace Engine coolant temp sensor.Check IAT sensor resistance seems to be ok. Throttle body nice and clean.What are the three vaccum hoses connected to the top of the throttle body?When i disconnect them no vaccum present.
what else could be?
Thanks in advance.
Bob.
I need a help here.
what else could be?
Thanks in advance.
Bob.
