otis24
Thread starter
Changing the PCV valve seems to have affected the transmission. I posted another thread regarding this. I had been experiencing harsh shift since I purchased the vehicle. That’s gone now, or appears to be.
check all of the hoses really well on the PCV system. they like to split with age. there is one on the throttle body to passenger side valve cover and the bit going to that pcv valve.Changing the PCV valve seems to have affected the transmission. I posted another thread regarding this. I had been experiencing harsh shift since I purchased the vehicle. That’s gone now, or appears to be.
i didn’t change my valve covers. original 2002 with 238k miles. i get a little oil in my catch can but nothing serious. can’t ever see any movement on the dipstick.How necessary is it to change out the valve cover to the updated one with the baffle? I didn’t change mine out. Only the updated PCV.
I installed the Dorman one and it fixed the oil consumption and smoke but the original was sludged up from coolant intrusion. I imagine if I didn't have the problematic castech heads leaking coolant internally then I would never have had any consumption anyway.My 2005s had the integrated PCV valve covers so my only mitigation was the most revised/updated valve cover. I’ll add that the latest GM and even Dorman valve covers also aid in the oil consumption decrease.
I would say stop putting crap into the oil, use it 100% from the bottle to start.I purchased my 2000 Silverado back in March. 5.3 V8. I did an oil change at that time. Mobil1 Full Synthetic HM 5W/30 and a bottle of Auto-Rx.
I just did an oil change in October. I had about 5k on the OCI. No signs of oil usage/consumption. My current fill is Valvoline R&P 5W/30. I also added a bottle of LiquiMoly Hydraulic Lifter additive, just because I had it and wanted to use it up. The vehicle is usually short tripped here in town; about 700 miles per month. This month, the vehicle did see one 600 mile round trip. In any event, the vehicle just used one and a half quarts of oil in about 1900 miles.
Wondering what I can attribute the oil usage to? Change of oil brand? Auto-Rx or Valvoline did some cleaning? I will have to monitor this closely.
That has not been my experience with LS. Not even closeGM often quoted 1 qt per / 1k as exceptable around those years.
why are you changing back to the check ball PCV?I changed oil this weekend. Earlier than I normally would have. Had about 5k this OCI. OLM was saying to change oil and I was on the “rinse cycle “ following an Auto-Rx retreatment. Switched back to Mobil1 FS. Also picked up the old style PCV valve. Will monitor for usage.
Care to elaborate? That's what GM pushed around those years & that was really close to what my 1998 Eldorado went through from 50k to 99k. Granted that was 300 HP high compression engine of the era. I've never owned a 5.3 but many 5.7's.That has not been my experience with LS. Not even close
The 5.7 350 and the 5.3 are completely different things. Your eldorado had neither.Care to elaborate? That's what GM pushed around those years & that was really close to what my 1998 Eldorado went through from 50k to 99k. Granted that was 300 HP high compression engine of the era. I've never owned a 5.3 but many 5.7's.
Not changing back at this time. If consumption continues, I may swap out PCVs to see if it makes a difference. If no difference, I will put the new style PCV back in and look at installing the updated valve cover to see if that improves things.why are you changing back to the check ball PCV?
can also echo this. my truck nor none of the LS powered trucks in the fleet burns any oil. we have trucks in excess of 14k engine hours that don’t burn anything.The 5.7 350 and the 5.3 are completely different things. Your eldorado had neither.
I have seen countless LS engines used under very severe conditions that did not use 1 quart per 1000 miles maybe a 1\2 quart per 5000k was the norm. Factory engine, not some built abomination
Yeah, the Eldorado quoted above to my knowledge never had an LS. Northstar 4.6 which did have some oil issues to my knowledge. I think there is a disconnect here between facts.can also echo this. my truck nor none of the LS powered trucks in the fleet burns any oil. we have trucks in excess of 14k engine hours that don’t burn anything.
I know they are different. I'm just reiterating what GM at the time was claiming for the GM vehicles or at least the N* engines. Just to note there is a difference between what an OEM considers "Normal" oil consumption vs what you may see for yourself. You may never have a problem but for the folks that have high oil consumption the OEM's can have very disappointing response of "It's normal at x miles/1 qt. 5.3L being low powered truck engine should do better than the N* I'd imagine.The 5.7 350 and the 5.3 are completely different things. Your eldorado had neither.
Around those years? That's just what most manufacturers say to keep warranty costs down. It was true for Ford of the era. Just because they have a statement saying that doesn't mean it's normal.Care to elaborate? That's what GM pushed around those years & that was really close to what my 1998 Eldorado went through from 50k to 99k. Granted that was 300 HP high compression engine of the era. I've never owned a 5.3 but many 5.7's.
Yep, keep in mind this poster mentioned their truck has almost 190k on the engine. I'd say it has plenty of leaks & burns some oil. Obviously, it's well out of warranty so GM's statements are moot but noteworthy.Around those years? That's just what most manufacturers say to keep warranty costs down. It was true for Ford of the era. Just because they have a statement saying that doesn't mean it's normal.
I'm just saying that it's not specific to those vehicles. I have basically the same engine with 270k miles and it uses basically no oil. It used around a qt per 3k miles when it needed that replacement valve cover still.Yep, keep in mind this poster mentioned their truck has almost 190k on the engine. I'd say it has plenty of leaks & burns some oil. Obviously, it's well out of warranty so GM's statements are moot but noteworthy.
