2000 Range Rover... (Saga)
Selah, Washington
I have a question that I can't seem to find a good answer for.
I had a customer come in for a service on their 2000 Range Rover. Checked the differentials, and they were dirty. So they requested we do them. Even though they just had their 90,000 mile service done at a dealership, which was supposed to include differential services.
I pulled the drain plugs on the diff's. The magnets where covered in metal shaving's. It looked like 50,000+ miles worth. Not 5,000 miles like it had been since they had them "serviced," at the dealer.
My paperwork, said to use GL-5 75-90. That is what I used. They called the dealer ***** about their "service," and the guy told them that it required synthetic gear oil, and nothing else would be ok. (While sidestepping out of the line of fire, totally ignoring the fact that it appeared they did not perform the service they charged the couple for) So of course the couple calls and ask me what the deal is. So I call Land Rover Spokane. (Washington) Land Rover L.A., and some Land Rover Dealer in Colorado. All three service departments say that standard GL-5 75-90 is what is required, and what they would use. They would not put synthetic in, unless it was requested.
So this couple, who have had nothing but problems with their range rover, comes back in, and asks me to put synthetic fluid in. I tell them what I have found in my research, and said that I would be happy to do it, but I would have to charge them again for the service. While we were talking about it, they decided to look in their owner’s manual. It stated to use synthetic fluid... that really is what confused us. They agreed to pay for the service just for their sake, as they have an extended warranty and are concerned about any problems that might be appearing in the differentials as the warranty is almost up. They have had numerous problems with this car, and even more problems with the warranty, so they wanted to make sure that they don't get screwed if the warranty company tells them the failure is from running a non-synthetic. (I must also say they have been really cool during this whole situation, and is partially why I'm here trying to find the answer)
Pretty much everything that I had found other then their dealership that apparently ripped them off, had said to use standard GL-5. Then we see that the owner’s manual states "Fully Synthetic 75-90."
So does anyone know what exactly Land Rover requires for the differentials in a 2000 Land Rover, Range Rover?
On another note, does anyone know any reason why a dealership would not pull the drain plug of a differential that has a drain plug when they are doing a differential service? From what it looked like to me, the dealership did not do the service. That is what I told the customer. I did mention it was possible that the dealer might have just sucked the fluid out and replaced it.
But that really doesn't make since why someone would go through that hassle when there is a drain plug, which would allow for a better and faster job. Plus the fluid I removed look like it had 30,000 + miles on it. I'm talking dark, dark brown. There is little doubt in my mind that the dealership did not perform the service.
The couple isn't upset with me at all, which is really nice. But we are all confused, so I really want to find the answer to this. My shop has been the only one that touches their Rover for it's standard maintenance other then the big "dealer services" as the nearest Land Rover Dealer is over 150 miles away from here. (Making matters just that much more complicated)
Any advice?
Reds,
I have gone through the same situation many times, but it sounds as if the couple was understanding with your dilema as well, since your paperwork showed mineral oil GL5 75W90. And I agree, if the fluid had actually been changed, it should not have looked that bad, unless the 5,000 mile fluid cleaned the crud from the factory fill.
My understanding (from talking to the local RR people) is Range Rover has specified synthetic GL5 75W90 since at least '97.
BTW, this is why I preach draining the factory fill in differentials before 10,000 miles, and since there are drain plugs on RR's (like Nissans), there is no excuse not to do so.
I was somewhat curious when I saw that it didn't take synthetic gear oil, but I figured my paper work was right... I guess not now.
At least we have gotten it taken care of for now. I just hope the dealer will fix the screw-up on their part. Either way, the owner said that he is going to come back at his next service and do the differentials again, just to check the plug. He said he'd rather spend the 100 bucks to see the drain plugs magnents and have the chance to get a clue on any potential problems they might be having with the differentials, then have them fail soon after the warranty expires.
You can actually get away with a GL4 lube in those diffs as they are spiral bevel, not hypoid, although I'd still use a GL5 ....
The factory fill for North America is Texaco Multigear 75W-90R, a Semi Synthetic lube, and this is what is specified in the dealer workshop manual.
courtesy of the Texaco UK site..
MULTIGEAR 75w/90R
A Semi Synthetic Total Drive Line lubricant treated with extreme pressure additives.
Allows product rationalisation
Long drain intervals 3 years or 300,000 km
Meets both GL4 & GL5 specifications
Approved for use in Land Rover axles & Vauxhall Fronterra front axles.
API GL4 & GL5, API MT-1.
BTW, Land Rover owner handbooks are notoriously out in the lube specs. Mine states to use ATF Dex II in the manual gear box, while Texaco MTF 94 (10.2cSt @ 100*C, GL4) has been the factory fill since about '96.
I forgot to add that the change schedule for the final drives is dump at 10 000km/6 000 miles, then the next change at 160 000km/100 000 miles according to the stealer maintenance check sheet, with a check and top up every 12months/20 000km/12 000miles.
FWIW I checked a couple books and the Autozone web site and all said to use a GL5 Synthetic 75w90 gear lube. This applied to all models of the Range Rover for the year 2000.
It not hard for me to make that leap of the diff not being serviced. I've heard of that happenning before. How would the normal average Joe know that the service was not done? What I cannot do myself goes to a local shop I trust, not the stealer. Any warranty work would go through a stealer as I watch them perform it, if possible.
