I discovered why the new motor wouldn't run.....and also found out why my old motor fried.
I suspected there was a problem with the timing....because it had fuel, spark, and good compression. And at the end of a 5 second crank/starting attempt, it would hiccup just once.
How can the timing be off? You can't adjust the timing and the dizzy only goes in one way....
Took the dizzy cap off and look at the rotor. There is supposed to be a set screw that holds the rotor in place. It wasn't there.....and upon further inspection, there was no hole/threads showing where the screw was to go into. I popped the rotor off, and it had somehow twisted on dizzy shaft!!! There is a flat area on the dizzy shaft and a corresponding flat area on the rotor to ensure proper orientation, and somehow it had STILL TWISTED. My guess is that it was between 40-60 degrees off.
Who knows how long this was occurring. I'm assuming that having the timing advanced or retarded that much, would have caused all sorts of pinging and pre-detonation and caused everything to run hot and maybe burn the valves or cause the head gasket to blow. What do you think?
The old dizzy had to go in my new motor, and this is why I couldn't get it started. I put the rotor on correctly, threaded in a temporary set screw, and she fired right up.
Tomorrow, everything will be buttoned up, including a new rotor and cap.
Has anyone ever heard of something like this happening?
