2000 Mitsubishi Galant CODES!! HELP
Chicago, IL
My aunt has a 2000 Mitsubishi Galant ES 2.4 L engine.
The Car has 224K miles and running like a beauty.
It has 2 codes I need feedback on if you guys have experience on these codes.
The Codes are:
P0170
P0420
Any ideas on where to begin to fix these two codes.
Agreed, A P0420 is 99% of the time a faulty converter..
P0170 code only means there is some kind of a air/fuel mixture problem, it is not specific. Check the fuel trim information to determine if the car is running rich or lean. Positive numbers on the long term fuel trim indicate the system is adding fuel due to a lean condition. Negative numbers mean the system is removing fuel due to a rich condition. Or a "smoking gun" like a vacuum leak, low fuel pressure, Or faulty pressure regulator.
