quote:
Originally posted by TooSlick:
Coolant reacts with engine oil to form an acidic sludge. The first parts to show abnormal wear are the main and rod bearings. This is the reason why your lead levels are elevated and why the viscosity is so high - it should be in the 60-65 SUS range in this case.
I'm not sure about the reluctance of ** labs to flag this issue? But unless you're feeding bananas into the intake, you have a coolant leak that will only get worse.
