2000 4Runner is needing injectors for the 3rd time in a year...some bad luck with rebuilds?
As the title states, I'm headed towards my third set of injectors in the past year. Last May I threw a code for P0172 (bank too rich). I bought the 4Runner in 2018 with 201k miles on it, and the private seller had put a full set of new injectors in it. When I pulled them out last May, they looked like a cheap set, probably from a box store or Rock Auto; something India made. I can't blame them I guess since they were selling $5k vehicle, and a garage did the work so it was probably out of their control. It now has 251,xxx miles on it.
I use genuine TOYOTA parts from Ourisman Toyota in Richmond VA. In the past couple of years I have replaced:
- TPS
- IAC valve
- all new Denso coils
- Sumitomo plug wire set
- New NGK Plugs
- Cleaned the MAF sensor
- Magniflow cat-back exhaust
- new fuel pump, pick-up tube, sock filter, and sending unit
-the fuel filter back around 2019
Last May when I did the injectors I replaced the valve cover gaskets, PCV valve, fuel pressure regulator, O2 sensors, and the engine looked excellent inside given the mileage. It still doesn't burn oil and there are no signs of coolant issues. I used Motor West Performance injectors for the replacement. The repair went well, it ran great, my MPG went up a bit, and the code went away.
5 months later in October I got a P0172, again, and MWP sent me a new set with new intake plenum/manifold gaskets, and fuel rail banjo bolt seals. Again, the code went away and it ran great. I'm getting quite good at getting the injectors replaced quickly. I'm very careful inserting the new injectors using the provided lubricant, to not cut the o-rings, and also careful to not be sloppy with getting the lubricant where it doesn't belong.
The other day my Runner stumbled a bit at high idle after starting, and it surged a few times on me. I now had a good idea what was happening as this happened the other times as well. Yesterday my LTFT was is at -32.xx% and it actually died on my at my house, but it started right up. The LTFT was in this range the other times as well. If it does through a CEL it has only been for the P0172. Every time after the repair, my STFT and LTFT go back into the -10% to +10% range, and I monitor it for about 2 weeks until I feel confident its fixed. In that time it runs fine, and get 17.5-19.25 MPG.
Am I just having bad luck with "remanufactured" injectors? I know MWP has a good reputation, but I can't come to any other conclusion other than I keep getting injectors from them, and at least one fails after a few months. I know it may not be likely given their reputation, but it's also not impossible, and this is getting OLD. I read on the IH8 Mud forums that Denso fuel injectors are not truely rebuildable because they are a sealed unit. They can be cleaned, screens replaced, replace o-rings, and tested, but they can't replace the solenoids, coils, pintle, return springs, or valves. If this is true, this is a great point and piece of knowledge.
page 2, post #24
https://forum.ih8mud.com/threads/refurbished-fuel-injectors.1225257/page-2
The reason I believe that its a bad fuel injector, and at this point not another issue, is that new injectors always fix it with no lingering problems. I would think that if its related to the ECM, bad wiring, or bad Toyota fuel system replacement parts, the issue would persist immediately, even after new injectors. All the other data from the IAT sensor, MAF sensor, TPS sensor, Coolant Temp sensor, and 02 sensors are correct and with in a healthy range.
I would like some thoughts on this. MWP has a Million Mile/Lifetime warranty on their injectors for the 5VZFE, but I'm very tempted to just get a new set of genuine Toyota Denso injectors from Oursiman Toyota at $166/each, and hopefully be done with this. Yota Shop has Aisin injectors that are claimed to be new OEM (I know Aisin makes good stuff) for a much cheaper $89.37/each, but I'm wondering if I need to stop cheaping out on this, bite the bullet, and just go new Toyota injectors. If this happened again after doing so, I would be confident that there is another issue. I just don't know what that might be if a new set of injectors always solves the issue.
For fun and general interest, I've attached a few photos of what the heads look like once the covers removed; I was happy with what I saw. I'm liking Valvoline in our Yotas, and I'm currently running the Valvoline Restore and Protect.
