2 cycle break in
North Carolina
I just picked up a hitachi leaf blower i ordered. Does anyone use a break in regimen with small 2 cycle engines? the manual says you can use oil mixtures from 25-50:1. I was thinking of doing the first tank at 40:1 then 50:1 since my chain saw calls for 50:1 i can use the same fuel mix. Any suggestions?
No break-in required. FWIW I use 40:1 Belray H1-R in all my 2T stuff. I've got a few.
Stihl BR550
Husq 562XP
Husq 550
Jonsered 2188
Stihl MS362
Robin NB211
Stihl FS90
Originally Posted By: spasm3
Any suggestions?
Yes. For the amount of work you're doing, "can gas", while seemingly expensive, is going to save you from a bunch of cussing, time, and frustration.
Stihl MotoMix, TruFuel, etc. Just do it!
Any suggestions?
I can see buying that and putting it in before storage, i assume its ethanol free?
Yep, no E. High octane with a looong shelf life. Makes a good purge fuel or for those that simply use little 2T mix.
Any suggestions?
+1 on can gas, and probably more important is initial warm up, sure you can just get on it, but old timers will tell you to give the engine a few rev and idle cycles before putting the balls to the wall. Ever seen someone warm up a two stroke dirt bike?
