I have been doing long term cleaning of my Dad's 2000 Dodge Caravan over the last couple of years. So I have been using the Super Tech ST 16 filters.
I installed one a couple of weeks back and my Dad started noticing noise on start up. I thought it was a 1/2 second on start up or something? I was horrified to later find that it was making noise like a bad engine. I started the engine and it was making racket even after running for a few moments. Sounded like it was not getting enough oil to the lifters. I cut the first filter apart and found one piece of a metal sliver. My Dad put about 2k miles on the first filter with a good 600 mile trip in there. I told my Dad it's probably a bad filter before I knew it was making noise after the first couple of seconds after start up. So I told him lets try another ST filter because I had one left from another WallyWorld and the same thing.
I did notice that it would start and not have noise on some starts and on other starts it would make noise on start up and it would go away after revving the engine. Other times the noise would not go away after revving. Really weird.
At this point I was telling my Dad I think I will have to get a used engine and install it. But I told him for kicks I will throw on a Pure 1 filter. I then replaced with a Pure 1 filter. Sounds normal on all start ups. I have never seen a filter that caused a problem that went beyond an initial second or two of noise after start up.
I will add the filters have been getting pretty filled up with junk with all the cleanings I have been doing. That being said the first filter had 2k miles and the second one had 15 minutes on it and the engine sounded about the same.
I thought maybe the bypass valve was defective on the first one, but after the second one still caused noise I kind of ruled that out.
