Originally Posted By: SteveSRT8
Originally Posted By: 440Magnum
Check for varmints in the air intake, then light 'er off. IF it were me, I'd cycle the key from "off" to "run" and back without cranking two or three times to pressurize the fuel system before cranking it, that way you don't crank as long before it fires.
While I see your point, cranking a bit (which is slow) will push some oil into the lubricated surfaces before it starts.
Its been fairly well researched and proven that a fast start is better than prolonged cranking. Starting right up builds oil pressure in fewer rotations of the crank than grinding away with the starter.
I wish you could hear our new 3500 Express fire up. Even at 80 degrees it immediately revs to around 1300-1500 rpm! A bit disconcerting to me at first, then i made some inquiries and found out this is strictly designed to get the oil up to the cam sooner for the VVT setup and such.
Friends don't let friends dry crank!
My F150 does a similar thing, revs immediately to 1500 and then depending on temp will idle down after 5-30 seconds. My buddy's Honda F4I motorcycle would idle up to 3300 or so on the first start in the cool spring.
I still know a few who pull the coil wire in the spring, and one who did that on his freshly rebuilt 350 to prime the oil pump. Ouch goes the cam.
Slug_bug - as most have said I would just check everything over and make sure fluids are good/no furry friends made home somewhere in the car. Hop in and fire it up. Thats about all I do with ours and only issue I ever had was carb related. Rear float stuck and filled the intake up to the carb with gas before i caught it.
