Originally Posted By: Saturn_Fan
Originally Posted By: Headnsouth
Automatic Transmission Fluid and Filter Replacement
Removal Procedure
Raise and the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Place a drain pan under the transmission oil pan.
Remove the oil pan drain plug.
Remove the oil pan bolts.
Remove the oil pan.
Remove the gasket.
Remove the magnet.
Remove the oil filter.
Remove the filter neck seal.
The transmission oil pan gasket is reusable. Inspect the gasket and replace as needed.
Clean the transmission case and the oil pan gasket surfaces with solvent.
Air dry the transmission case and surfaces.
Wish I had someone to answer my questions this detailed. Nice job!
Wish I could take credit but all I did was c/p from the online service manual.
Here's the reinstall:
Install the filter neck seal.
Install the oil filter.
Install the oil pan gasket to the pan.
Install the magnet into the bottom of the pan.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the oil pan to the transmission with seventeen bolts.
Tighten
Tighten the oil pan bolts to 11 N·m (97 lb in).
Apply a small amount of sealant GM P/N 12346004 to the treads of the drain plug.
Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 18 N·m (13 lb ft).
Install Dexron® III Automatic Transmission Fluid. Refer to Fluid Capacity .
Lower the vehicle.
