Vehicle: 1998 Nissan Frontier XE 4x4 2.4L 5spd 175k miles
I'm at wits end... I've tried everything that I can think of and thrown parts left and right at this truck, and am stumped.
How it began (last Fall):
Loud thump at hard shift and vibration at speed led to the discovery of a disintegrated carrier bearing. Easy enough, right? Replaced the carrier bearing with minor issues (cussing) and all is well, or was it? Took the truck for a celebratory test drive only to discover that, after backing out of the driveway, the truck had developed a severe chatter. I mean a chatter so sever that it felt like the drivetrain wanted to tear itself from the body. All I could think of is "[censored]... there went the clutch." Having replaced ONE clutch, literally by myself, in my 20s... I decided that I had no desire to undergo that mess again.
I opted to take the truck to a local "reputable" shop to have it diagnosed and fixed so I wouldn't have to mess with it. Took it in (horrible experience... story for another day...) and they confirmed that it needed a cluth/pressure plate. Fast forward a few days and I pick the truck up. Back out of the parking spot and the chatter is still there... again, story for another day...
Side note, when I replaced the carrier bearing I somehow got the two piece axle out of alignment/balance. Reorienting the driveshaft lessened the chatter.
New clutch and pressure plate. Check!
Over the course of 5 or 6 months I've tried everything that I could attribute the "chatter" to:
Replaced a CV axle with a busted boot. Nada.
Replaced engine and transmission mounts. Nada.
Replaced driveshaft with one piece unit and new ujoints. Nada.
Now, for the chatter. It's only from a stop. (why I assumed clutch) If I'm generous with the RPMs and feather the clutch it's lessened. The drivetrain feels like it has slop i.e. cruising at 2000rpm stabbing the gas you can hear the metallic clank of slack being taken up/let out. If I don't rev match, subsequent shifts are rough...
Now for the weird part. I was overthinking the chatter in traffic the other day and randomly tried something... I engaged the transfer case (hubs not locked) and it seemed to lessen the violence of the chatter on takeoff. What?
The chatter almost "feels" like axle wrap... like wheel hop. The leafs are factory (2 leafs with an overload) and I don't know the history of the truck. Could weak springs cause the chatter? Maybe the pinion angle getting goofy?
Transfer case? Ugh.
Any ideas of what to check? How to check? Thanks in advance BITOG!!!
Transfer case? Ugh.
