Hi, guys.
I've searched the archive and read some info saying Dex 6 maybe shouldn't be used in the power steering on my old Buick.
The problem is, even using advanced search and title only, I'm getting right near every topic in BITOG. Yeah, I've used Google as a workaround search... but mainly, I'm hoping to learn if one of the 2 ATF's I have on the shelf is advisable as a power steering fluid for this car.
Well, from my other exploits some will know that my shop vac is already drooling oil... so I thought I may as well use the same rig to vacuum out the power steering fluid for a partial change at OCI's.
What I have on the shelf: Valvoline High Mileage ATF (dex/merc) and also a few quarts of Valvoline Dex VI.
Would either of those be usable for power steering fluid? No leakage is apparent. No noise. It ain't broke, so I'm gonna fix it... ?? Yeah, I know... my BITOG OCD kicking in again.
If either of the above would be suitable, I'd like to use it since that's what's on my shelf. If both are NOT a good choice, please advise what you recommend.
Thank you,
Larry S.
10*bears
Thank you,
Larry S.
10*bears
