Recently bought a 1997 Toyota Avalon (has the infamous V6 Sludge engine)with 99K miles from an auction. Did an oil change at 99K and another at 104K using quick lube place and conventional 10w30 oil. I also put in a bottle of Progard/Techron every tankful (went through a few cases from Costco).
At about 104K, I notice intermittent puff of blue smoke when I start the car first thing in the morning (happened every other day). A quick check on the net had me worried that my car has sludge and engine is on the way out.
At 108K, I decided to "clean" my engine and used Mobil Clean 7500 (18% greater cleaning power so it says). Car ran fine but I noticed a slight acrid oil burning smell (My mechanic has previously mentioned that I had a slight valve cover leak on the inner valve cover). I assume it must be the Mobil Clean working its way through that valve cover.
After 1K, I changed oil and filter with fresh Mobil Clean 7500/used Toyota Filter. Guess what, the puff of blue smoke went away!! Car now runs very smooth and quiet. But no more blue smoke on start up.
It is either that Mobil Clean somehow cleared away somthing or perhaps the Progard/Techron additive was causing the puff of blue smoke (I am no longer using the Progard/Techron).
Any idea what is happening??
