I have a 1997 Silverado fixer upper that I have been working on. The maintenance history on it is mostly unknown.
I have always had front end/steering issues. The one that is most vexing to me is the steering wheel will not return to center when turning. From what I understand this is usually due to the steering box being adjusted to tight. I have adjusted it looser, tighter and everywhere in between, still no change. Driving me nuts.
Have replaced many new parts in front:
New
Pittman arm
Idler arm
All tie rods
Steering shaft/rag joint
EVO sensor
4 new tires
new PS fluid
Front end alignment
Wheel bearings adjusted
Really don't want to spend $250 plus for a rebuilt gearbox only to have it not fix the issue.
Any ideas on this?? Tom
New
Pittman arm
Idler arm
All tie rods
EVO sensor
4 new tires
new PS fluid
Front end alignment
