This is the inline 6 motor. I have owed this truck since it had 60k on it. Some signs the prior owner did not take good care of it. I had the head gasket replaced at 69k. It now has 96k on it and it uses a lot of oil (has since I got it). It seems to use about 1 quart every 1000 miles perhaps a litte more. If I take it on a long trip (2000 miles or so) it will use no noticable oil. It burns the oil with around town driving only. It does not smoke or leak at all (no smoke even on start up)
I beleive the problem would have to be the valve guide seals (which must not have been replaced when the head was off as the machine shop said the valves were fine so they must have assumed the valve guide seals were ok to).
What do you think about this and should I be concerned? I bothers me bad enough I have considered selling/trading it in but I do like the truck. I have a perfectionist personality so stuff like this bugs me.
I use Rotella Synthetic 5W-40 in it now and have run many different weights and brands and they all do about the same.
Thanks
Andrew
Thanks
Andrew
