Originally Posted By: 0802
Update on this -- no further symptoms of transmission problems. Have replaced the fluid with Maxlife high mileage, old fluid was dirty, but could have been much worse.
Shifting from 1st to 2nd is better but noticeable; every other shift is almost unnoticeable unless you are really paying attention.
Hopefully this problem wasn't a problem. Almost 195,000 miles now; will continue to "improve" by adding a cooler and better filtration at some point, but I don't feel any emergency at this point. Keeping my fingers crossed and knocking on wood that this keeps together until I can afford a newer, lower mileage version.
Did you ever figure out if it has the 4L80E or 4L60E? I would have assumed with the diesel that it would have the 4L80E but the hard 1-2 shift reeks of 60, not the 80.
