I've noticed for a while now that I have puddles of clear/yellowish fluid on the ground, so I put a drip pan down so that I could get a better idea of where it was coming from. Only probem is, I'm still not sure. I thought at first it might be oil, but the color of the fluid is consistantly clean looking, whereas, oil will darken over time in the crank case and come out of your engine darker. I know it isn't power steering fluid because mine is reddish colored, not clear. My question is: Are there brake lines that run along the axle which can leak out around the front center area of my car? If you are facing my engine, the leak is more toward the passenger side, but not all the way towared the tire.
