Car came in on Thursday for a CEL/MIL diagnostic, 81,000 miles & super clean other than some trans leaks & a oil pan leak which I noted on the repair order.
L-Code 3.8L/4T60
History Codes...
P0341 Cam/Crank Error
P0342 Cam Signal Circuit
P1406 EGR Pintle Position Error
Hard Code...
This car is NOT OBD-2, Nor is it OBD-1, I've always called them OBD-1.5, It has a OBD-2 data link connector & alphanumeric generic trouble codes.....But little else in common with true '96 & up OBD-2 vehicles.
P0341 sets "hard" with closed loop fueling control enable, Clears with each key cycle, Saved in history/memory, Normal with OBD-1.5.
The first thing I did was pull the alternator & check the Cam/Crank sensor harness branches for rotted wire insulation from oil contamination. Nothing found.....Harness in fantastic shape!! Re-taped the harness/conduit with TESA underhood tape.
During harness inspection.....Cam & Crank sensors have been replaced recently, Looks to be Standard/Wells/BWD replacement junk?
*Looked over the trouble tree for P0341, Came to the conclusion that the ICM sends a Cam & Crank signal to the PCM & P0341 sets if one of these signals are missing or intermittent.
*Cam/Crank Error "Count" increases steadily as the engine idles, Has a slight "hitch" every now & again at idle.....My theory is it's losing #1 cylinder location & the PCM is switching back & forth from sequential injector operation to batch fire.
*Using my Vantage Pro in dual graphing meter mode.....I back-probed pin RB8 & RB9 at the PCM connector. Good clean 5 volt square wave patterns on both circuits. Recorded over 800 1-second frames while wiggling the harnesses & cam/crank connectors with NO drop-out in either signal.
*I also did a "tap-test" on the PCM.....Along with "Flexing" the PCM connector, Results were inconclusive as the error count steadily increases no matter what & the Hitch/stubble is erratic.
*Performed a "Drag Test" on PCM terminal pins RB8 & RB9, Both have GOOD drag on them.
I came to the conclusion that the PCM is either faulty or has a cracked solder joint.
The DRAMA filled part of this diagnostic
My shop foreman/service writer disagrees & thinks its a sensor or wiring issue. He doesn't believe in scope patterns & thinks that I should follow the trouble tree to the letter.
I tried to explain to him that I AM using a voltmeter on BOTH circuits, The ONLY deviation I made from the trouble tree was.....The engine is running while I performed the wiggle tests & I can see & record the actual patterns.
We had a heated argument that I wouldn't be able to paraphrase on the board. I RARELY cull a PCM as being faulty & I understand his position in the company as it pertains to NOT allowing technicians to throw parts at a vehicle on the customers or the companies dime.
L-Code 3.8L/4T60
History Codes...
Hard Code...
