Welp, I'm back with another car concern, many thanks to those that helped with my previous post.
4.0 Engine 4l80-e trans, only 60k miles. Pretty much a cruising the coast car / sonic stop & dine / beach trip car.
Much before that it was a show car from another collector. Everything on the car is original.
Anyways, I like to start new when I get a new car, new oil, coolant, transmission fluid and such so I know what's in there. So I'd like a much more in tune person/s take a look at my selection of tune up choices and voice any concerns.
Spark plugs will be NGK iridiums. Factory is copper.
Oil will be Delo 10w30 HD synblend oil, SN rated. Has no oil leaks, unknown what's in there.
Coolant G-05 pretty much what I use in everything.
Transmission fluid - Valvoline dex 3 conventional. Only sump 1 gal through dip stick tube each year, to slowly move fluids as I don't like full flushes on the unknown, fluid is still bright red.
Differential fluid - idk... ik I need a gl5, and a 90sae or 80w90. It's positive traction, and from what I hear, ford's blue tube of addictive works great in it. I also know synthetic Isn't wanted in it via the manual. Why? Due to natural rubber/leather seals.
I don't think that'll matter but better safe than sorry, and it's got a fill and drain bolt, easy with a pump. So any advice on that oil would be most appreciated.
Bought it at cruising the coast so limited info on it from seller, mostly told me about the oddity Features of the car.
Thank you in advance.
