Originally Posted By: jmb106
Last weekend i changed my Honda MTF to Amsoil MTF a little more costly hoping the good shift feel last longer than the 12-18 months the Honda fluid lasted. In my 94 Accord.
If you were using the new Honda MTF2 with the green cap before switching to Amsoil, its much thinner than it used to be, and 5th gen accords, or any older honda seem to sheer the new stuff up rather quickly losing shift feel.
Here is a comprehensive MTF list created by Molecule listing the many flavors of MTFs available to us today. You will notice the new MTF2 is around 6cSt@100c, where as the original was around 7.5cST@100c. I believe this is why the ~9cSt@100c Synchromeshes last longer shift feel wise. ymmv
Here is an updated list of dedicated GL-4 and a few GL-5 MTL's, Updated 12/7/2014:
A. These MTL fluids are closest to a Kinematic Viscosity of 6.xcSt@100C (About the same viscosity as a DexronVI) and SAE 70W to 75W or so are:
1. Castrol Syntrans FE 75W,
2. BMW (Pentosin) MTF-LT-3,
3. Honda MTII or MTF 2.
4. Ford FML-XT-11-QDC
5. Volvo Manual Transmission Fluid (6.4 cSt) [Recommended for: type M65 5-speed with 6-cyl. engine, M66, MTX75 and MMT6 and of the type M56, M58 and M59 from and including model year 1996. Meets Ford specification WSSM2C200-D2]
B. The next higher viscosity MTL would be the 7.5 cSt@100C versions (About the same viscosity as a the original DexronIII/Merc)
1. Royal Purple's Synchromax
2. Ravenol MTF-2
3. Honda MTF
4. VW part number G052512A2
5. GM Manual Transmission and Transfer Case Fluid
6. BMW (Pentosin MTF 2) MTF-LT-1, 2
C. The next higher viscosity MTL would be Castrol Syntrans V FE 75W-80 8.0cSt
D. The next higher viscosity MTL would be BG Synchroshift II 8.2 cSt
E. The next higher viscosity is Mopar Type MS-9417 MTL 9.0cSt
F. Valvoline MTF Part Number 811095 9.2 cSt
G. The next higher viscosity MTL would be Pennzoil Synchromesh 9.3 cSt
H. The next group of MTL’s are in the 10.x cSt (SAE 75W80) range:
1. Redline MTL 75W80
2. Amsoil MTF (9.7 cSt)
3. GM Synchromesh’s
4. Volvo MTF 645
5. Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic MTF (Carries a GL-5 rating as well)
6. Lodexol (Morris Lubricants) MTF
I. The next higher viscosity MTL would be a 12.0cSt@100C and SAE 75W85:
1. Redline MT-85 – 12.0 cSt
J. The next higher viscosity MTLs in the 14-15 cSt ( SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Synthetic Manual Transmission Fluid XT-M5-QS
7. Subaru Extra-S Gear & Transmission Fluid carries a GL-5 Rating because it is used in common sump driveline systems.
Edited by MolaKule (12/08/14 05:32 PM)
