1994 Honda Accord Manual Trans Fluid
Charlotte, NC
Hi, my brother has a 1994 Honda Accord (non-VTEC) with a 5 speed transmission and he wants to change the fluid in the transmission. He's been asking around and can't get a straight answer as to what he should be using.
I checked around a bit and from what I'm seeing, it's saying 10w30 motor oil and I am having a hard time coming to grips with this....
Is this what's required or is it something else? I'm open to suggestions with brands and whatnot.
I just put some Pennzoil Synchromesh in my son's '96 Accord. Readily available at the parts stores and cheap.
I recall that our 94 integra 5 speed said in the manual that 10w30 could be used as an alternate, but we always ran a honda mtf from the dealer.
I always hated the clutch in that car, but the shifter was as slick as could be under any conditions.
Originally Posted By: Chris142
Why are you concerned about motor oil in it? It works fine if that's what's recommended by the maker. The car has had motor oil in the trans for 20 yes.why change now?
Better shift feel for starters.
I do remember older Honda/Acura standard transmissions recommending 10W30 motor oil. But today, the oil is different possibly requiring a MTF. And IDK if using todays 10W30 would be good enough 21 years later. Or, since the change to SM or SN!
Originally Posted By: qdeezie
10w-30 motor oil
10W-30 motor oil was specified before ZDDP was reduced for the 1995 model year. 10w30 is NOT recommended any more, on account of the reduction in ZDDP. 10w30 has not been recommended since 1995, so you're looking at old information.
Honda sells an excellent MTF that is rich in the additives that the Honda manual transmission needs. It has the ZDDP that used to be in motor oil, and is designed specifically for use in a transmission, not an engine.
Motor oil has changed. Friction modifiers for MPG... lower additive levels for emissions... 5w30, 10w30, and 10w40 were common recommendations for MT trans back then, but really usable anymore.
Pennzoil and Valvoline have pretty good synchromesh manual trans fluids available in local autopart stores. BG Synchroshift, Redline MTL, and Amsoil MTF are some great full synthetics.
Honda dealer also has a good MTF, but may be a little thin for an older transmission.
In a pinch, rice rocket JASO wet clutch motorcycle motor oil is about the only non-MT specific fluid I'd attempt to use.
Nissan and Hyundai have 75w85 GL4 MT fluids. These are closer to a 10w40 but will shear into a 10w30.
get with the times and use a dedicated MTF for synchronized transmissions. Can't go wrong with Redline MTL.
Originally Posted By: dlundblad
If 10w30 is what the factory is saying to primarily use, use it.
NO.
That information from 1995 is NO LONGER ACCURATE!
Like others have said the formulation of current
10w-30 motor oil is significantly different than it was twenty years ago and no longer provides adequate protection and performance in a manual transmission.
Use one of the current major brand synchromesh MTF products like Pennzoil, or Valvoline versions, it will perform better and offer good protection for soft yellow metals.
10w30 is indeed what the owners manual calls for.
In 1996, Honda started using their own MTF, which is essentially motor oil with some extra additives, most likely because of the API mandating reduced ZDDP from SH-on. However, even since Honda has been using their own MTF, they still state that motor oil can be used as a backup if Honda MTF is not available. Recently, within the past 5 years or so, has Honda started thinning out their MTF, and their backup motor oil recommendation is now 0/5w20.
I'd probably use Rotella T5 10w30 in Honda MT's more than 10 years old.
Here is a link to the 1994 Honda Accord owners manual.
Check out page 149
Do you all think that running a 10w30 such as Rotella or QS Defy or maybe even Mobil 1 High Mileage for a few thousand miles to clean it out a bit (never been changed before from the looks of it) will hurt before going with a dedicated MTF?
I took a 15 minute drive with 5W30 in the transmission prior to filling with Pennzoil SM. Honestly the 5W30 in the Nissan felt pretty good. Just get the cheapest motor oil you can for a quick flush, or skip it altogether.
No, because transmissions don't encounter the same contaminates as engines do. Instead, transmissions mostly become contaminated by large metal wear particles.
I'd use Honda MTF. They created it because they saw 10w30 engine oil wasn't ideal for their transmissions.
In the Owner's Manual, yes.
But that's meant as a temporary, emergency fill, to be replaced by MTF "as soon as possible" originally, and now "as soon as convenient".
In both cases warning is made of stiffer shifting on account of the oil not containing the correct additives.
And, here's the standard text that appears in EVERY Honda factory shop manual since 1995:
Always use Genuine Honda Manual Transmission Fluid
(MTF). Using motor oil can cause stiffer shifting
because it does not contain the proper additives.
Motor oil is not specified even as an emergency fill.
Since the OP has time on his hands, he should use the correct stuff, which is MTF.
Own 91 Civic Hatchback 3dr Si. If you are not going with Honda MTF then you can try this excellent alternative: Motul (Motylgear 10w-40,Technosynthese)
https://www.motul.com/us/en-US/products/oils-lubricants/motylgear-10w40?f%5Bapplication%5D=141&f%5Brange%5D=25&f%5Bviscosity%5D=28
