1994 Chevy 6.5 diesel
Ankeny, IA
This is my cousins truck (I ask for alot of recommendations for them, they have alot of cars and never change oil). Anyways, AMSOIL says it takes 7 qts of 15w40, but since winters are so cold, would a 5w40 be better to use? Im guessing it's a Detroit diesel. TIA
For the 6.5L 5w40 is fine. I would make sure the GP relay/controller and GPs are all good. Also in the winter if it has a cord plugging er' in will make it a lot smoother in the mornings
In Iowa I would go with Rotella t6 5w40 because its going to get cold, and 5w will make for an easier cold start up.
The 6.5 actually specs a 10W30 for colder/winter conditions, I run SAE 30 conventional year-round in my '93 6.2 diesel GMC pickup-but it gets a LOT colder in central Iowa than SW Ohio!
You got that right! AHe needs something that will work in sub-zero temps. Would a straight 30 be to thin for this application? (Rotella T straight grade, for example)
My 2 6.2 owner's manuals (the '93 and my now-scrapped '85 Sub) both recommended straight 30 for continuous operation, and I still have some of the AZ Delo 400 closeout 99cents/gallon stash left that I run in the 6.2 and an '89 7.3 IDI non-turbo F-450. The straight 30 should only be used in over 30F weather, so I use a magnetic oil pan heater for a few hours if I need to use them in cold weather.
