- Joined
- Jul 10, 2022
- Messages
- 3,676
My experience across 4 2x4's (2 240s, 2 264's) was they always rusted behind the rear wheel wells where the mud flaps were. They also wanted to rust at the rear door corners. The first was a 1975 so the fenders were also shot...those cars did not have the plastic cladding like this one, nor the molded mud flaps. Curious, why don't cars have mud flaps today, style, or function? Trucks have them...If you ever saw the amount of rust proofing on these cars from the factory you’d understand why they really did not rust much. I was a Volvo tech back in the late 80’s, early 90’s and I would have to soak my sockets in parts cleaner solvent periodically to clean off the undercoat. It was literally so thick you could not see the heads of some of the bolts.
The only things to keep up on are the PCV ( has a brass “flame trap”) which need to be replaced regularly to prevent the rear front seals from popping out. Keep an eye on the water pump for seepage and they tend to break the right motor mount frequently….I think more because the oil filter dumps oil right on it when you change it. The large round fuel filter canister under the car next to the main fuel pump is a 30,000 mile item, I was always amazed at the amount of dirt that came out of them @ 30K.
The heater blower fan is a giant pain if you need to change it too.
