1993 Chevy 3/4 ton 5.7 liter (350) knock on startup
CCI
New Mexico USA
1993 Chevy 3/4 ton, a little over 200,000 miles, 5.7 liter / 350 CID carbureted, there is a pronounced top-end knock on startup, then it goes away in a few seconds.
Any thoughts on what this is, what could be done about it, and if it even needs to be fixed?
I wonder if the oil is draining enough to where you get something of a dry start until oil pressure quickly builds. Oil filters usually have anti drain back valves and better ones use silicone. What oil and filter are you using.
I don't know what filter is on there, it's not my truck yet, but I will start there.
Looking on line with a web search, for whatever that is worth, it seems like this might be a common problem on the older 350s and relatively inconsequential. But if there is an easy and inexpensive fix I'd like to do that.
Try a carquest premium and some 0/5w-40 since nm can get cold. You can look through the fill cap to see how it is and if it's clean use 0/5w-40 if not Valvoline restore and protect 5w-30 could clean in up in a few changes.
More importantly since it's getting hot does the ac work. It being an r12 system since it's a 93 and not a 94+ it's not gonna work that great with 134a though some got converted properly but some didn't and work poorly. It's what makes the older r12 vehicles worth less than the slightly newer ones.
I think there's some alternative called freeze 12 where it's mostly 134a but with something else to make it work better with the mineral oil and pressures but I'm not sure.
  • Like
Reactions: D60
Curious, are you sure its carb'ed and not TBI?
As mentioned, get a fresh oil change done, I'd run a 0w-40 like M1 with that many miles on it.
The noise you are hearing is most likely lifter clatter from bleed down and then quieting once pressure has filled them back up. Does it happen at every cold start or just once its sat for a few days? Same noise on hot starts or no?
I wondered, too? I'm not that strong in GMT400s and I know the 3/4t+ often lagged in tech and body style updates, but a carb'd domestic in '93 is embarrassing.
I service an '89 K2500 with 350 that's TBI.
All the 88-95 GMT400’s were TBI stock. I’m wondering if the OP is mistaking the TBI unit for a carb. Not uncommon, they look externally similar for those unaware.
  • Like
Reactions: D60
Likely a piece of debris stuck in a lifter check valve, letting it bleed down after shutdown and pumping up after a few seconds on startup.
It may resolve itself eventually. Else, you'll have to take it out, disassemble, and clean it out.
93 GMT400 would be TBI from the factory, not carb, even in the 3/4+ trucks. Only way it would be carb is if someone swapped out the TBI for a carb.
  • Like
Reactions: D60
My 92 C1500 (5.7 w/161k) developed a startup knock last year, and soon got worse after engine warm-up around 5 or so miles. Oil pressure had been dropping a couple months before this took place. It ended up being main bearing/s. I went into the engine and replaced rod/main bearings & oil pump. My first time with this sort of repair. So far, 10 months later, it's doing fine. I think there's a thread here somewhere.
  • Love
Reactions: D60
  • Haha
Reactions: D60
Yeah, that's it!
  • Wow
Reactions: D60
