Originally Posted by ripcord
Did you pull it out to check it or was it like that? I wonder if it blew out after a backfire?
It was like that after i got home and pulled the doghouse.
Originally Posted by FlyNavyP3
The C6 is a robust transmission. I highly recommend at a minimum a Trans Go Shift Kit, they transform the way the unit works. Crisp shifts, without being harsh, increased line pressure, better all around. If you want gear control (the ability to command downshifts at any speed) the Trans Go Reprogramming kit will allow that as well. Both can be installed in the vehicle with basic hand tools.
By in the vehicle I mean the transmission stays in the vehicle, the entire C6 valve body unbolts and you can install the entire kit on a work bench.
Have seen a few YouTube videos of this, looks pretty easy to do. Thanks for the info on driving improvements.
Originally Posted by samven
After all the needed maint. and your sure its good to go, get some Firestone Ride Rite air bags for the rear end. Those older Class C's with a lot of overhang off the rear axle are notorious for sagging and dragging on every hill and driveway and most of them compound the problem by putting all the storage compartments in the back behind the axle. I got a set and installed them on mine in about 3 hrs. They bolt up with no drilling required.
And make sure you caulk all the seams and windows with RV caulk. Once water gets in it can rot the box structure as they use plain old 2x3 and particle bd.
Already got airbags in the suspension, I had to air them down because it rode pretty harsh. With 10-15 psi in then it was much better, but it was only me solo and I travel really light.
Originally Posted by bdcardinal
FarnsworthOP can send me their VIN and I can send them what it gives me. OASIS won't run because it is too old said:
"]https://www.bobistheoilguy.com/forums/attachments/usergals/2020/06/full-16339-45527-8b045181_7721_40e9_b8d0_0f7c393b2690.jpeg[/IMG]
