Wanting to do a pan drop on the 77 Buick that I got from my grandmother's estate. It only has 23,000 miles and I am sure it has never been done. The pan gasket is starting to seep pretty bad likely due to age. I am considering going with this fluid unless anyone sees a problem with it or has another recommendation. AC Delco III Fluid Would you use this or something else?
I'll also be ordering a Wix 58894 according to Rockauto. Probably try to take care of a few other tune-up/maintenance things as well.
