1969 Pontiac Owner's Manual
VA
I went down an Internet rabbit hole and found myself reading the model year 1969 Pontiac owner's manual. I thought the oil specs might be of interest.
Old Car Manual Project
Oil and ATF change intervals are on the previous and next pages.
Oil: 4 months/6000 miles, whichever is first. 2/3000 for severe service.
ATF: 2 years/24,000. 12,000 miles for severe service.
Original Dexron always had a 24,000 mile normal service interval, Though people rarely ever followed that. I can certainly smell old Dexron from a mile away.....It's a foul/sweet odor is about the best I can describe.
I had a '68 GTO for a couple of years in the mid 70's. The link to the owner's manual shows a recommendation of 10W20 for Winter use in HO engines. I'm sure I had never heard of that weight at the time. I was a fool that used straight Quaker State or Pennzoil 40 wt. racing oil much of the year (was that oil even detergent?) and 10W40 Quaker State in Winter. I know that I stuck to 3k mi. OCI's.
That 5W recommendation freaked me out. 😳
I think the owner's manual for my 70 Monte Carlo says something similar. It's been a while since I've looked at it but that info sounds familiar.
The owner's manual for my '63 Bonneville had similar oil recommendations. I think I still have the manual someplace. The 10W and 20W stands out....
Why?
If you live in a cold climate, it would definitely need it, especially conventional motor oil as it thickens (increases viscosity) due to wax content.
I was fine with the 5W-20 and 5W-30; it was the straight 5W that got me. Even though it was only to be used at 20°F and below, the thought still makes me cringe.
and to think that we have folks who still think drain intervals recommended for the oils of more than fifty years ago are appropriate to the oils of today.
Cars that were in extreme cold climates and parked outside needed the really light viscosity oil. The nylon timing gears that shucked off were a true testament to that. (Especially Pontiacs).
Back in the '70s/'80s when my sister had a Catalina, my brother a GTO, and I had a LeMans, I changed all the timing chain sets with steel. It was easy to remove the HB and timing cover on those.
