19" computer rack choice
Near the beach in Delaware
Some racks have square holes for cage nuts and other have a threaded hole. On the surface the threaded hole would to be easier and better but some of the better brands like StarTech have square holes for cage nuts.
Thoughts?
Square holes are now the standard. There is equipment made to snap into square holes without the use of nuts.
  • Like
Reactions: Pew
I have populated so many racks during my career having either threaded holes or speed nuts with clips. I always preferred the racks having threaded holes on its rails. Having to install the clips was an added step racking equipment. I never had the threads strip on a rack's rail. It usually happens when an inexperienced person using a cordless drill to install the rack screws doesn't have the drill torgue set properly.
Didn't people's Dads teach them to start all screws by hand and the "feel" of screwing in a screw with a screwdriver. Mine did. (OK when he taught me we did not have cordless anything except a cordless flashlight).
I don't think cross threading was the major issue but overtightening the rack screw using a drill.
If there was a situation where paint got into the threads, I had a 10-32 thread chaser to clean things up.
In a world where nobody cares about what they do… you expect people to do things right?
Except I went to three different Vans shoes stores yesterday looking for a specific pair and everyone was so helpful. So I guess a culture of customer service and doing good work still exist. But that’s so irrelevant, my bad.
Since it is the densest in weight, a UPS should always be placed at the bottom of the rack to keep the overall center of gravity low. APC supplies wide head bolts or special washers which pass through and engage square holes. Cage nuts are not needed.
One of our AutoCAD drafters was never wrong (/s) and insisted on identifying the holes in the rack as 10/32" instead of 10-32 or #10-32.
Made me crazy! I'd have a different drafter correct it afterwards.
