190F thermostat, no problems here. On the LS1/2/6, the only problem I can see with a 190F thermostat is in stop/go driving in hot weather. Radiator fans are electric and don't come on till coolant hits 226F and higher, unless you reprogram. By then it's too hot and you're reacting to an overheat instead of preventing. With an aluminum motor, it sheds heat well so a 190F isn't that hot. You should really be looking at oil temp as well, colder oil = thicker oil = less economy. This past summer with a 190F thermo and manually switching on the fans, I run 220-240F oil temp with 5w-40 oil. Now with weather 40-70F I see 190-210F oil temps unless I romp on it. I have run a 160F thermostat, never noticed a problem but I never did a comparison to really find out. I don't believe you get better fuel economy with a 160, not in PA and certainly not this time of year. This is all for a stock motor. Now if you are running a turbo or blower or did work to bump up compression or are lapping the car at high rpm's for long periods of time then yes a colder thermo would be in order, along with a radiator upgrade and fan reprogram. I would first look at a better/larger radiator and airflow to maintain temp (rather than running colder to prevent overheating) as that's primarily where the problem is. Had a 1999 ss and those years had a 180F thermo as oem, which I think is a better choice than the 190F especially for warm weather driving.
Best reason I can think of you getting faster 1/4 mile on lower thermostat is it was allowing the motor to run full timing and not see any knock retard which is common with today's crappy ethanol'd pump gas. Full timing on cooler thermo = more power compared to better efficiency at hotter coolant temps but with less ignition timing. Run a 180 or 190F thermo and a higher octane fuel, bet you run your fastest time.
gurkha: diesel ignition is based on heat in the cylinder, how do you figure a lower thermostat/coolant temps = better performance?
2002 camaro ss, 34k miles, M6, stock except for k&n filter and ngk iridium plugs,
this is 3rd pull out of 5, oil temp at 220F, coolant about 200F (less than 210 mark on gauge).
I was running vp 100 octane unleaded, so I know I was getting full timing. Also running mobil 5w-40 oil, pennzoil synchromesh in M6, and redline 75w90 in rear. I also made an effort to drive car on highway just before the dyno to get drivetrain hot. I was looking for maximum #'s.
