I did put a 160F T-Stat in my 1996 LT1 Corvette last spring....good thing is that the Vette has temp gages for everything (coolant, motor oil and Trans fluid), so I can report what happens when you go from a 180F to a 160F.
180F: Coolant temp is from 201 to 235 (mostly right around 210) depending on ambient temps, Motor Oil is from 205 to 245 (mostly around 216) and tranny fluid is around 200 to 220 (mostly 210.
160F: Coolant temp is from 173 to 210 (mostly 180 to 190), motor oil is 175 to 200 (mostly around 185 to 190) and tranny temp is 160 to 200 (mostly aound 175 to 180)
Bottom line, I like the 160 F in the Vette the best because I do not like the high temp spikes in engine oil and tranny fluid temperatures with the 180F.
[ April 06, 2003, 05:58 PM: Message edited by: Alex D ]
