'16 F150 2.7 Ecoboost
oh
This is the third OC on this truck, all following the IOLM. Oil in sample is Citgo SuperGard 5w-30, which is labeled as a syn. The oil and filter were changed at the time of sampling, I used the same Citgo SuperGard and MotorCraft filter. 9,190 mi. on sample 29,190 mi. total on truck. Fe...............30 Cr...............<1 Pb...............<1 Cu................4 Sn...............<1 Al................4 Ni...............<1 Ag...............<1 Ti...............<1 V................<1 Si...............30 Na................2 K................<1 Mg...............14 Ca.............2045 Ba...............<1 P...............712 Zn..............719 Mo.............. 35 B................<5 Viscosity cST 100C........7.3 Fuel.......................3% Viscosity is low, but wear levels remain in check. I will continue to follow the IOLM as long as wear metals remain in check.
Michigan
It bothers me that the viscosity has dropped out of the 30 range, and that fuel dilution is 3%. 9.3 cSt is the low limit for 30 weight, so 7.3 is 20% below that. Maybe you should talk to your dealer about the fuel dilution, which is also contributing to the loss in viscosity; what is acceptable on the Ecoboost? Is 5w30 the recommended viscosity for the 2.7 Ecoboost? I would consider going to an oil thick enough to keep viscosity in the 30 grade at the end of an OCI.
roadrunner1
oh
At 9,190 mi. an Fe # of 30 is not high. I don't like the lowered viscosity either, but wear numbers seem to be in check. I will sample at next OC and see if fuel dilution has settled in at this level, as long as wear rates stay at an acceptable level there really isn't an issue.
As compared to what? Another engine in that family or another engine from a different family or other manufacturer?
Clovis, CA
That may be but why not try to bring the number down anyway ? Plenty of oil brands out there.
MTL, CANADA
Id run a shorter interval on same product or change oil brands like Merkava said and do another OCI with 9190 or as close to that mileage as possible for comparison. Did you get the truck on a good run prior to changing the oil? Is it short tripped alot? These might be the indicators and might reflect the need to reduce the oil change interval if another oil gives you similar results. Maybe need to reduce to 7k mile changes instead of 9...
roadrunner1
oh
Originally Posted By: bigj_16
Roadrunner, Is this the first UOA on this truck?
This is the second UOA, and I forgot to add TBN of 2.1. I bought this new and it gets driven round trip of 45 mi. daily in mixed city highway. It also serves as a delivery truck delivering light loads. 3 ppm per 900 mi. of Fe is not high in any engine family.
I did not realize it was only the second UOA, so higher FE readings would be expected. It should drop as wear metals wash out. Long term, 3PPM would be double what I have experienced per 1000 miles. Splitting hairs in the end though, it is parts per million.
The Garden State
Just curious, did you check the iOLM to see what % oil life was indicated at the 9190 miles. I'm betting that it was showing about 10% life left. The iOLM in our Explorer seems to drop 10% for every 1000 miles driven, no matter the driving conditions are. Whimsey
roadrunner1
oh
I did and it was at 2%.
Buffalo, NY
I would cut down the OCI to 7,500. Oil is cheap with rebates and I think you'd see better wear numbers and lower fuel dilution... I agree the iron is nothing to be particularly worried about...
dnewton3
Staff member
Indianapolis, IN
rr1 - I don't have enough data on these newer little engines yet, but given it's only 30k miles "new", and your OCIs are around 9-10k miles, this is probably a bit of break in lingering. I hear good things about the performance of these little units; how do you like it?
roadrunner1
oh
The 2.7 is amazing to drive, its the complete package with ample power throughout the power band and a very comfortable ride. I am well aware of the low viscosity as it was low on the previous sample also, but wear seems to be in check. If I had viscosity this low and elevated wear numbers I would be concerned. This seems to be accepted with DI & Ecoboost engines. Again wear numbers all seem OK so no alarms going off here.
South Carolina
At least your viscosity of 7.3 cSt is within range for a 20-weight, but I guess your 2.7 Ecoboost is supposed to take 5W-30. For whatever reason, my 1.0 Ecoboost is supposed to take 5W-20, or 0W-20 in cold climates. That's what the book says, so that's what it is getting as long as I have a powertrain warranty. I will be doing UOAs, though.
Douglas County, Colorado
My guess is that some of that has to do with the sump capacity vs. displacement.
South Carolina
I am not quite making the connection. Does it have something to do with oil temperature?
More oil, relatively, doesn't break down/dilute as quickly.
