I have 04 Discovery with a 4.6L that was derived from a Buick 215. I've been researching the best oil to use in the vehicle and found that since the engine design is over 40 years old and was designed for a 40-50 weight oil that a 15w40 would be the best to use since it has flat tappets.
I normally get a lot of noise when I first start the engine after its been sitting a while, most say is normal for the engine I don't like it. I change the oil every 3k mostly because my commute to work is about 16miles. I'd like to try shell Rotella 15w40 or Delo 15w40 but don't want to hear that much racket from the valve train now that its cold. I figure the noise might be worse with at 15w40 than a 10w40. I tried GC (0w30) for a short while during the summer. There was almost no noise at idle but the valve train noise at operating temperature when I accelerated did not make me feel comfortable.
The lowest temp we have seen so far here is about 32 degrees. Would the 15w40 flow well at this temp or if it gets colder than that?
I also heard that the shell may "stick" to the engine components better after the engine has been shut down. If it does I'm thinking that the 15w40 might not be so bad.
I've also considered Castrol Syntec 5W50 but don't know what affect it will have on gas mileage once warm as it's not that great to begin with. Any thoughts would be appreciated.
