15W-60 for KTM 690?
I have a 22 KTM 690, and the recommended factory oil is 10w-50, but most recommend using thicker 10w-60, some even recommending 15w-60. I've been looking online for 15w-60, and looks like the only one available is Motul 300v Factory Line 15w60 100% Synthetic. I wonder if this is a suitable oil that I should try, or if I should stick with 10w-60?
I also read that 10W-60 breaks down to 10W-40 just after a few hundred miles?
The 690 has been refined into a very good engine, with larger oil passages and improved rocker arms/bearings. Rocker arm bearing issues are far less common, and camshaft failures are in the past. Of course, wheelies and stoppies can affect oil flow to the cylinder head. Infrequent oil changes are a real problem, as is running the oil level low.
You are correct, nearly all oils with a wide viscosity spread will contain significant quantities of viscosity index improvers. And even the highest quality VII's will shear down in motorcycle use. It is good to note that oils with VII's revert to the base oil's film strength under high loads and a 10W-50 will not match the extreme load carrying capability of a high quality 50 viscosity oil.
Oils with high HTHS are worth considering for engines with known oil related failures. I tend to like Mobil 1 20W-50, with its high HTHS and robust shear resistance. It is probably the most robust commonly available oil, anywhere. Yes, I know it is a V-Twin oil, but there is nothing unique about it, other than very high quality base stock and a very normal, robust additive package.
Regardless of oil choice, change it frequently.
I don't ride in 0F, but I do ride in 0C. The record cold I took the bike out was -9C.
I've been using KTM/Motorex 10W-60, but I've heard the hydraulic chain tensioner works much better with 15w-60, but wasn't able to find it, other than the Motul I posted in my original post.
Yes, it looks like there are not many choices of 15W-60 oil. But if the factory recommendation is 10W-50 and people tell you to use 10W-60 or 15W-60, why don't you use 15W-50? There plenty of choices out there, including Mobil 1, Motul, Bardahl, Ravenol.
Regarding the viscosity, 15W-50 should be the most shear stable and also is the closest to the factory recommendation.
Take a look at Amsoil. They make a 15w50 and 15w60 that will work well for you.
I run the 15w50 in my 790 Adventure.
And yet Honda still recommends a 10w-30 in their comparable bikes.
This single cylinder bike makes north of 71HP at the rear wheel in stock form and the 2025 version makes 74RWHP. There are very few Honda motorcycle engines with that level of internal load and stress. In fact KTM absolutely crushes Honda's output in just about every category. The 1390 KTM V-Twin makes 190HP.
While a fine motorcycle, the new multi cylinder Honda CB750 makes 73HP at the rear wheel. Less than KTM's smaller single!
Do you have a link to these dyno performance claims? I see Cycle World dyno results, from 2019, show 59 hp at the rear wheel.
Cycle World had over 70 HP at the rear wheel for the 690 Duke. Is the enduro tuned different, knobbies, per se, may not grip the dyno as well?
Data comes from WMR, the local KTM shop w/dyno. They are honest and clearly state what they get for RWHP. The 2025 has 5 more now at 78HP at the crank, IIRC. The 690/700 has gone up, multiple times and quite a bit since 2019
