Hello all. I have a Sears mower with the 6.75 hp Tecumseh engine. The so-called "high torque" engine, only available in certain areas. Anyway, do you think it would be ok to use Delo 400 15W-40 in the thing? Summer mowing months are coming! Thanks.
I didn't know that Sears sold anything with a Honda OHV engine on it. All I have seen have had the 5.5 hp OHC engine. I have one of these that I got about 4 years ago. Since changing out at 5 hours the 30W oil that came with it, I have used Mobil 1 5w30, changed once a year. I have an hour meter on this little engine, and it is used around 50 hours a year. The M1 stays a nice golden color, and so far, does not burn any. I use the mower thru the winter for leaf cleanup, so the 5W is nice.quote:
Originally posted by Triple_Se7en:
I have a new Sears mower with the Honda OHV engine. I put the lawnmower oil that came in the box in my daughter's Ford as a top-off... then put HDEO dino Motorcraft 15W-40 in the new Honda engine. After the first season, I'll switch it to full synthetic.
Was the Pennzoil 5w30 synthetic? The B & S chart only recommends synthetic multigrades, I believe. I use M1 5w30 in my Honda OHC 5.5 hp mower, and it looks fine after 50 hours. That's when I changed it. It stayed about 1/16th inch overfull the whole year. I've had this mower for about 4 years; changed it to M1 at the 5 hour mark, and have never had to add any oil between yearly changes. I have had to buy one new rear wheel which split apart, and I really need to get two new front tires as they are getting slick and are giving much less traction.quote:
Originally posted by 90lsteg:
I was using Penzoil 5W-30 in my Sears 22" with 6.75 hp Eager-1 engine. Manual said to use 5W-30 under 40 degrees and 30 weight at higher temps.Thought the 5W-30 would be similar to 30 weight oil at operating temp.The used oil was black and much thinner when I changed it.There was silver flecks in the used oil also.
Found old stock Delo 400 15W-40 for $1.25 a qt and decided to try it after reading these posts. Cannot tell a difference in how the mower runs but the oil is cleaner and not breaking down like before.
No this was old stock dino Pennzoil. I think it was SH or SJ. I think the engine is made by Tecumseh because the air filter has "Tecumseh" stamped on it.quote:
