take a look at http://www.fdu.com/oilanalysis.htm for the results of a 15k mile test using Amsoil Series 2000 0W30 in a 99 Ford Explorer 4.0 SOHC.
TS, look at my post above.. I call him and provided everyone with more info on what he had done as for air filter and such.quote:
Originally posted by TooSlick:
Aldive,
The second sample shows elevated silicon levels of 24 ppm - since this engine has 72,000 miles this isn't gasket leaching, but rather abrasive particles. This is very high for a sample with only 7500 miles on it and explains the higher wear rates in the second analysis. I would check the airfilter as well as for leaks downstream of the filter. It is very common to have air leaks at the ends of the rubber "bellows" that joint the airbox and intake manifold. A good way to locate these is to spray some carb cleaner or even WD-40 with the engine idling. If the idle speed increases when you spray a joint, you have found your leak.
TS
quote:
Originally posted by BOBISTHEOILGUY:
Yes, it is the same oil for both analysis..
yes, he did change the air filter, thus the lower nitration levels.
He did his last analysis by changing the filter, and adding one quart of new oil back in, thus the reason why the cST's are lower in the second sample but still show higher than 30wt.
Yea.. I misunderstood. In that case-pretty impressive. However 25K does seem like a reach as was mentioned before.quote:
Originally posted by Pablo:
mdv, he says 15K in his post.
And I have questions, too in my post.![]()
OK, I understand the concept presented by the curve and I never really understood chemistry in high school. But doesn't this curve show the effect of titration using an alkaline substance on an acidic substance or do I have it bass ackwards?quote:
Originally posted by satterfi:
What Bob is talking about on TBN depletion can easily be seen by looking at a titration curve.
Looking at the generic curve below, it takes a lot of acid to go from a pH of 11.5 to 10. But once you are at 10, it only takes a few ml of acid and you are below 7.
