Originally Posted by dave1251
Simple Maxlife meets the same specs as Magatec
Wrong again. Maxlife blend, the one the OP mentioned, is not dexos1 Gen2. .. dave1251, you said a Maxlife High Mileage was cheaper than Magnatec. Nope, not if you're comparing versions with similar performance levels: The Maxlife that DOES meet the same specs as Magnatec, the full syn version of Maxlife, is more expensive than Magnatec.
Originally Posted by kessellrun
How does Magnatec help with the timing chain?
The dexos1 Gen2 certification includes a timing chain test, among many other tests too over & above SN GF5. Meets are Ford lower specs too.
And yes I am open to a new oil with a new car. With this car, I am willing to spend a few more bucks if there is decent support for a better option.
You're right in taking a different approach to a newer engine than the older engines, as you indicated in your original post too. ... At 75,000 miles, you can switch to a "High Mileage" oil like Valvoline full synthetic with Maxlife Technology as they call it. For now, the engine is still kinda new, so my choice would be to go with the Castrol Magnatec 5w20 with a Fram Ultra oil filter for the most bang for the buck as I've said.
