Originally Posted By: Redland1
I should have explained why I did not want to go the oil sample route.An oil change for me cost $39 with tax and that is using Delo 400 and the oem ACdelco oil filter.According to the DIC and my running conditions,it would have me change out the oil between 7500-8k miles which I thought was pretty good.Now that I have deleted,the DIC is no longer accurate and I figured since all the emissions are gone the oil would be able to go longer.An oil sample will run me $35 and i am guessing that the oil could run to about 15k.Now in that case I rather dump the oil at 8k and have fresh oil and filter rather than taking it out to 15k with no real cost savings.
Obviously, you are welcome to what you want with your truck; no one is going to take that away from you.
I would NOT extend your OCIs out past the IOLM, unless you do UOAs. The risk, however remote, is pretty large should the unthinkable happen.
Yes - data clearly shows that 15k mile OCIs is easily doable with a Dmax such as yours (deleted and regens via the 9th injector). Essentially, although you do have regens, they don't affect the lube or engine. (They do burn fuel; it's a fiscal cost). Your Dmax is akin to mine, now that you are deleted, in terms of wear data.
It's your choice to make. You can extend your OCIs and data tells us that it's very safe even out to 15k miles, even using conventional lube stock. In fact, I don't see any statistical differential in macro data between syns and dino out to 15k miles.
Caveat Emptor.
