Originally Posted By: Trav
Originally Posted By: dubie2003
The short is that the cost of Proto is the same as Craftsman and believe it or not, Craftsman tools outlast the Protos in my case.
Ok if you say so. Even if you add a 20 and 21 to the craftsman its not even close.
I don't now what kind of Proto you ave been using but they superior to Craftsman in every way, if there was something wrong with them you should have contacted Proto they have great CS.
http://www.toolup.com/Proto-J1200F-MASD-15-Pc-Metric-Combination-ASD-Wrench-Set-12-Point
http://www.sears.com/craftsman-professional-13-pc-metric-12-pt-full/p-00945964000P
You are missing the point completely. OP asked 6pt or 12pt. I provided my experience. You then took that and decided to go on a pilgrimage to convert me to drinking the koolaid.
Again, my situation is not the same for everyone so take this and everything else you read on the world wide internet with a grain of salt.
The final straw was the 10mm nuts on my fan clutch. That caused me to use a vise grip to remove the rounded nut and then make an last minute trip to Home Depot to get a new nut so that I could put the pulley back w/o fan and run my new electrics. From that point forward, 6-pt whenever possible and 12-pt if I absolutely have to.
Which brand was that 12-point wrench that rounded off the corners ?
There were 2 wrenches used for that. The first was a HF whatever followed by a stanley. I believe HF did the majority of the damage and Stanley was unable to salvage it.
In the end, I have decided that it is best for me to stick with 6pt whever possible and thru dumb luck, my craftsman wrenches (and sockets) are working. Maybe I got a higher quality batch..... lastly, items that require specialty tooling, SnapOn/MAC/MATCO/etc.. get my business.
