My pressure washer has a Briggs 900 Series Intek engine. In my previous thread, I talked about needing to replace the carb due to the carb spewing gas everywhere. I changed the oil when I replaced the carb, and it definitely seemed like some gas had gotten in there, as oil spewed out of the fill hole. I had some Pennzoil Conventional and some Valvoline 4 stroke 10w40 motorcycle oil conventional.
I decided to use the motorcycle oil, since motorcycle oil is built to operate in dirty, wet clutch environments. I know it's not energy conserving though, but has other additives in it that should make up for it, I am hoping.
The manual for this particular *engine* states that I can use up to 15w-50 (full syn) for temps between 20F-120F. The *pressure washer* manual says nothing of the sort, only recommends 5w30 syn, SAE 30, and 10w30, saying increased oil consumption will occur with 10w30, same as the engine manual. There was no mention of the 15w-50.
I almost exclusively use my pressure washer in the summer months, when temps exceed 90F. I am thinking I will be okay, however, I wanted to encourage some discussion on it.
Here are pictures of the engine manual:
Pictures of pressure washer manual:
Thoughts? Valvoline motorcycle conventional 10w40 seems to have a SF/SG/SJ rating, which the manual says is okay.
