I have a Kawasaki FT730V on my zero turn. I mow 5 acres once a week. Fuel is 89 octane ethanol free, treated with seafoam. I was using Kawasaki 4 stroke ktech 10w-30 and switched to Kawasaki 4 stroke ktech 10w-40.
I'm noticing a increase in fuel consumption. Can I safely mix the two oils to create a 35w in hopes of reducing fuel consumption while still getting the benefits of using the 10w-40 albeit reduced? Looking for a sweet spot. Manual states I can use either or due to temperature range. Logically it should be fine.
I also tend to mix my breakfast cereals with good results. 50/50 of raisin bran and fiber one. Seems to work well. I can tolerate the taste better while still maintain a healthy bowel movement.
What say you?
What say you?
